Old 09-05-2012, 12:13 PM   #7 (permalink)
oil pan 4
You never want smaller tires on a tow vehicle.
You will be giving up a lot of weight capacity.
I see these are metric tires, unless they are LT truck tires you will need to derate their load capacity by 9% I think it is (I dont know why but the tire manufactures recomend this when putting a car tire on a truck or SUV, so do it).
The only reason you would ever want to consider a smaller tire when towing is if you were having trouble pulling the load.
Other than that bigger is better.
Taller Tires - EcoModder
