Old 09-06-2012, 02:46 PM   #17 (permalink)
mcrews
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Let's speak clearly here.
1. smaller diameter THAN STOCK (this is important because a smalll tire than what is currently on the vehicle MAY NOT be the stock size) will produce higher rpms and worse mileage.
2. A larger diameter than stock will produce a lower rpm thus better mileage.
IGNORE the speedometer/odometer.
I use a gps set on meters instead of miles to to calibrate my Scangauge. (setting to meters gives a more exact measurement to set by.) I then change back to miles.
Once I have the gps and scangauge giving me a precise mph reading I tend to ignore the speedo.
IF you want more tourgue to tow then smaller diameter MIGHT achieve that, given load wieghts. But a smaller tire will not....in general produce better mpg.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
