Old 09-07-2012, 12:15 AM   #22 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Originally Posted by darcane View Post
Trying to figure this out for my '01 HX.
Did you ever figure out a good solution? Did you interupt the Yellow/Black wire to the injectors similar to SentraSE-R?
No, I haven't had time to revisit this. I've been using the switch and turning the key off then back on before I bump start it to reset the immobilizer. You'll have to insert the switch before the yellow/black wire splits to the injectors but after it splits off from the wire that goes to the immobilizer. If you hunt for it before I get around to it, post up!
UIUC Aerospace Engineering
www.amateuraerodynamics.com
