Old 09-07-2012, 11:58 PM   #13 (permalink)
aerohead
simple
Originally Posted by christofoo View Post
What about the the blinkers (if it isn't clear from the picture, they are under the bumper). Can you think of a solution that doesn't require a compound curve in transparent plastic, or 5 different components? Probably the easiest thing to do is to move them to the bullnose - but even that is too much.
"Brutally simple" is a key requirement for this one, although I may well make a more sophisticated bullnose for the Civic.
Thanks
You could leave the lights where they are.Then provide fenestrations(window openings) in the new nose which diverge as the move away from the lamps.If the new overfascia has a simple plan curvature,clear plex could be bent around the curve and attached to the outside.No compound curvature necessary.
