Old 09-03-2012, 07:33 PM   #11 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
You've got the center section; now build side sections just like it at 45 deg. angles to the side.
.|____|
..\|__|/
It'll look like that from the top view. And yeah, buy a spool of wire meant for trailer lights, some butt connectors and a wire stripper. It'll be easy!
Old 09-07-2012, 07:11 AM   #12 (permalink)
Recreation Engineer
KamperBob's Avatar
Black Stallion - '02 Toyota Tundra 4WD xCab
Half Pint - '06 Yamaha XT225
Warm up
Originally Posted by christofoo View Post
I realized the reason my data seemed subjective is because it used the first data point as the initial speed for the model. But since the GPS exhibits noise, there is some error in the first data point. And since I can slide my starting point around, that adds a subjective element. Error in starting speed will translate into an error in Cd.
I made the model initial velocity a fit parameter instead. The subjectivity in my data analysis disappeared.
This data is garbage. Probably my bullnose has no effect, at least in this incarnation.
I have always felt like the drag in my car goes down after it's run 5-10 miles, especially in cold weather. One day I jacked all the wheels up to figure which breaks are dragging, and I found that the front wheels are at fault. But I don't think it's the breaks. I can't hear any rubbing or sliding at all. It must be a differential or the transmission. (Yes, it was in neutral.)
I think what we're looking at in this chart is a change in temperature and viscosity of an oil that needs to be changed. The manual transmission is the most likely candidate. This car has 222k on it, there's a decent chance is has the originial manual transmission, and there's a decent chance the transmission oil has never been changed.
The only thing this chart suggests to me is that my impressions were correct and until I fix it there is no point in doing any drag testing on this car. (Or maybe it would work out okay if I did a warm-up drive first, but it would still be a wild-card.)
I notice a warm-up effect on long trips. Some times I overnight in my RV at a rest area for example. In the AM my ScanGauge shows lower MPG initially. It takes some warm-up time/miles for performance to recover - summer faster, winter slower.
Recreation Engineer
Old 09-07-2012, 11:58 PM   #13 (permalink)
simple
What about the the blinkers (if it isn't clear from the picture, they are under the bumper). Can you think of a solution that doesn't require a compound curve in transparent plastic, or 5 different components? Probably the easiest thing to do is to move them to the bullnose - but even that is too much.
"Brutally simple" is a key requirement for this one, although I may well make a more sophisticated bullnose for the Civic.
Thanks
You could leave the lights where they are.Then provide fenestrations(window openings) in the new nose which diverge as the move away from the lamps.If the new overfascia has a simple plan curvature,clear plex could be bent around the curve and attached to the outside.No compound curvature necessary.
Old 09-08-2012, 03:09 AM   #14 (permalink)
Formula SAE Engineer
If you want reliable data, you need at least 15 samples per test. It's a statistics thing.
Max Trenkle
Student Engineer - TTU Motorsports
