Old 06-08-2008, 06:16 PM   #141 (permalink)
ttoyoda
ttoyoda's Avatar
ebacherville
I have found out that misting the foam very lightly (between layers) with water or injecting water into the deposited foam with a sringe will greatly speed up the setting time. The foam seems to set up by absorbing moisture from the air, normally.
