Old 06-08-2008, 05:16 PM   #141 (permalink)
ttoyoda's Avatar
ebacherville
I have found out that misting the foam very lightly (between layers) with water or injecting water into the deposited foam with a sringe will greatly speed up the setting time. The foam seems to set up by absorbing moisture from the air, normally.
Old 06-08-2008, 06:31 PM   #142 (permalink)
Blue - '77 Chevy P/U
Originally Posted by ttoyoda View Post
ebacherville
Hmmmmmm what brand again ??
Old 06-08-2008, 06:52 PM   #143 (permalink)
ttoyoda's Avatar
from here:
http://greatstuff.dow.com/greatstuff/diy/directions.htm
"# GREAT STUFF™ Insulating Foam Sealant is tack free in approximately 15 minutes and cures in 8 hours. Curing is speeded by humidity and moisture."
Old 06-08-2008, 07:17 PM   #144 (permalink)
from here:
thats what i buy most
Old 06-08-2008, 08:12 PM   #145 (permalink)
Veggiedynamics
Volt12 - '12 Chevy Volt base
ebacherville
wow thats interesting.. guess covering it up didnt help.. lol.. its pretty humid here..
As for curing time i have noticed the thicker it it is the longer it takes to cure.. i've had 8 hour cures when I cut into them be sticky inside still.. ill let them cure up good and hard.
Old 06-09-2008, 12:41 AM   #146 (permalink)
Veggiedynamics
i wonder if i can get "great stuff" to finance the car, got about 14 cans into the car so far..luckily it was on sale last time i picked it up.. lol
Maybe bondo to for the resin and bondo i have on the car..
Old 06-09-2008, 01:04 AM   #147 (permalink)
EcoModding Minded
Chris D.'s Avatar
Lunar Mist - '02 Toyota Tacoma SR5
90 day: 25.31 mpg (US)
Silver Streak - '08 Toyota Corolla S
90 day: 38.25 mpg (US)
Send a message via AIM to Chris D.
its lookin badass man, keep her rollin..
I finally made some progress on my trailer mod as well today.
Old 06-09-2008, 01:26 AM   #148 (permalink)
i like the way you think,,,you need some pics of you spraying ,with the lable out and you with a
Old 06-09-2008, 03:38 AM   #149 (permalink)
EcoModding Minded
Chris D.'s Avatar
I forgot which company makes the spray foam, but they have a thing where you post up what alternative use for the foam and so fourth..
Old 06-09-2008, 09:20 AM   #150 (permalink)
ttoyoda's Avatar
To be expected if the only way the foam can get the moisture it needs to cure is from the outside surface inward. Funny to think that the foam is capable of passing water (vapor?) thru the hardened part into the soft core.
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1056 12-14-2024 12:21 AM
crx hf help need more info, rear wheel skirts RP-CLMBR Aerodynamics 2 07-16-2008 09:24 PM
Repping the old school Hondas - 85 CRX HF 1GCRXHF Introductions 4 06-16-2008 01:14 PM
New to the forum, with my RX-7 EV Project... BigMouse Fossil Fuel Free 14 02-28-2008 04:14 PM
AFS Trinity EXTREME Hybrids!!! cfg83 General Efficiency Discussion 10 01-18-2008 07:15 PM
