Old 09-10-2012, 10:46 AM   #1 (permalink)
Quezacotl
Scandinavian creature
Golf ball - '94 Volkswagen Golf III
90 day: 28.46 mpg (US)
Fooling Lambda-sensor for FE?
I was just thinking, what if you fool the lambda-sensor to give false reading, about 100mV less or something, driving it into bigger than 14.7:1 ratio, and so it would run leaner?
I did search a lot about this, but with mixed disgussion. But since it is'nt not much disgussed, should it belong to Unicorn corral?
But i was thinking, that if you just put a variable resistor in between lambda signal and ground, big enough to not to burn it. Would that be enough? ..Or in series with the signal.
And of course, A/F meter so you see the results.
Any thoughts about this?
Brrrmm
Now selling preassembled MPGuino's!
http://www.mthtek.net/mpguino/
