Old 09-10-2012, 10:46 AM   #1 (permalink)
Scandinavian creature
Golf ball - '94 Volkswagen Golf III
90 day: 28.46 mpg (US)
Fooling Lambda-sensor for FE?
I was just thinking, what if you fool the lambda-sensor to give false reading, about 100mV less or something, driving it into bigger than 14.7:1 ratio, and so it would run leaner?
I did search a lot about this, but with mixed disgussion. But since it is'nt not much disgussed, should it belong to Unicorn corral?
But i was thinking, that if you just put a variable resistor in between lambda signal and ground, big enough to not to burn it. Would that be enough? ..Or in series with the signal.
And of course, A/F meter so you see the results.
Any thoughts about this?
Brrrmm
Now selling preassembled MPGuino's!
http://www.mthtek.net/mpguino/
Old 09-10-2012, 10:44 PM   #2 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
The problem is that the narrowband sensors are more like rich/lean switches. The sensor makes the switch at 14.7 and no resistor will change that.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
Old 09-11-2012, 04:23 AM   #3 (permalink)
Yea, i thought about that too.
Hm, thinking more, it may not work in my car afterall, because i think the ECU will just read is it bigger or smaller than 1.
Or well, i could test it someday and see how the ECU reads it
Brrrmm
