Old 09-10-2012, 01:11 PM   #11 (permalink)
MetroMPG
90 day: 55.97 mpg (US)
90 day: 70.75 mpg (US)
90 day: 61.17 mpg (US)
Is that because, being throttle body injection (TBI), it fires once for every cylinder, rather than the typical MPGuino installation where you tap just one of the injector wires in a multi-port injection arrangment? If so, you should be able to calibrate the MPGuino and apply a correction factor to make it work with TBI.
