Old 09-10-2012, 08:45 PM   #64 (permalink)
adamj12b
EVVette - '71 Chevy Corvette Coupe
Originally Posted by Gulah View Post
So why not just make the regenerative braking available? Sorry, but I don't understand why not do it, if it is so simple?
Its not simple to do for multiple reasons. Number 1 reason being series wound motors cannot simply be used for regenerative brakes. Number 2 would be that it requires a totally different power stage that has 4x the amount of high current switching devices. It is not a cost effective controller to produce to be used in such few applications. I am using a series wound Warp11HV in my Corvette with a transmission. Because of this, I do not need to reverse the motor. The regenerative braking would be nice to absorbe a little bit of energy, but When I get time, i will finish my regeneration controller for adding a large truck alternator to the tail shaft to act as a brake. But that wont be till the car is done in the first place.
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
The Following 2 Users Say Thank You to adamj12b For This Useful Post:
evimarn (10-22-2012), Gulah (10-22-2012)
