Originally Posted by ttoyoda
ebacherville
I have found out that misting the foam very lightly (between layers) with water or injecting water into the deposited foam with a sringe will greatly speed up the setting time. The foam seems to set up by absorbing moisture from the air, normally.
wow thats interesting.. guess covering it up didnt help.. lol.. its pretty humid here..
As for curing time i have noticed the thicker it it is the longer it takes to cure.. i've had 8 hour cures when I cut into them be sticky inside still.. ill let them cure up good and hard.
