Old 09-11-2012, 05:46 PM   #53 (permalink)
MetroMPG
90 day: 57.73 mpg (US)
It does look like it might be a little bit high:
If it's adjustable at all, I'd lower the end by a bit more than the diameter of the lug nut hole in your wheel cover.
Note: I first rotated the Neon image to make the bottom of the F&R tires lie on the same
horizontal "ground plane" as the template, then marked the apex of the roof with the yellow triangle.
Made with: http://ecomodder.com/forum/showthrea...ion-21952.html
