I allow mine to just touch under extreme extension, as when the side of car is jacked up. There is also another factor worth considering. If you study the suspension, particular lower A arms, you will see that the inner part of the A arms move very little on suspension extension, so you can get that part fairly tight. Of course, I'm working with an Insight Gen1. Other cars will have different considerations.
