Old 09-15-2012, 09:51 AM   #14 (permalink)
jime57
OurInsight - '06 Honda Insight
Originally Posted by Otto View Post
Question on Coro coverings of moving suspension members, such as front control arms:
Anybody rigged Coro such that it is attached to the moving control are and flexes up and down with it? Flexible fairing, keeps wind from dragging on the control arm. Would this work and how to attach?
I think aluminum might be a better material to use if you are going to attach it directly to the suspension parts. You can do simple one dimensional bends and then bolt it in place. I haven't done this myself but am seriously considering doing it on some parts of shock brackets on rear of my Insight Gen1.
If you have convenient holes, you could use T anchors, those spring loaded thingies that are pushed through holes in drywall to provide shelf anchors, etc. I've done this on my car in places where I only had a large hole to work with. You can also find "edge" brackets in the automotive hardware section. These push over an edge and have a screw thread internally. (You have to drill a hole to get the bolt in.) I don't much like the edge brackets which only allow a screw to be used because screws can come out and puncture someone's tire. Zip ties are good. If you have a flat surface and are willing to drill a hole, the plastic 2 piece "pop" fastners work well and don't rust. Lots of options
