Old 09-15-2012, 06:25 PM   #3 (permalink)
some_other_dave
There are electronic devices out there that will modify the signal of the throttle pedal for you. I think "Sprint Booster" is one? They are generally intended to give you a quicker response, which is the opposite of what you want, but you may be able to program them or find a way to modify them so that the top 20% of the signal happens only at the very end of travel. That would give you the option to use WOT in the rare instance you actually need to.
-soD
