Old 09-17-2012, 12:19 AM   #10 (permalink)
RH77
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
Originally Posted by nemo View Post
The gas gauge and tach have me thinking electrical. Check all connections going to fuel pump and sending unit (in tank unit?) and ignition system, especially grounds.
The grounds definitely need some attention in the engine bay. I've messed with a lot of wiring for mods, so that seems like a reasonable fix. It's easy enough to clean mounting points or add more ground wires (yes, I did that on an Evo as a tuner-mod a while back). If it's clearly corroded at the tank / sending unit, that may be a give-away.
Originally Posted by ron View Post
OK ,so here is what my son and I went thru with his problem . we replaced the filter (pain in the butt location )fire wall ,plug wires and plugs. again (I dont like the small electrode tip ) Made a pressure test adaptor for the fuel line , throttle position sensor , got a used distributor from the local wrecking yard , tested every thing again and again. always stalled and would start up again but with increasing frequency in lenght to refire . when I had exhausted every other option and spent hours and lots of cash on things the computer codes pointed to, I finally came to the pump. auto zone unit around a 100bucks ,reused our pickup and sending unit. and it runs great . thats why I say just do it and eliminate it as a problem and dont run below 1/4 tank the fuel cools the pump.
We were in the thick of the heat/drought here in KC until Isaac dumped enough rain to fill things back up (most of the corn crops not surviving) so it may have been the last straw in it's long, hard life of empty fills and extreme temps. I think the rear seat might have to come out and then a metal cover with a few screws expose the fuel components and it's good to go for replacement.
Looking at the big picture, there may be a fuel delivery and electrical problem (possibly vacuum to fine-tune). It may not have been enough to throw a lean-condition code or emissions fault when the ignition was in flux. We'll see.
Thanks again to everyone for the advice! Like with lots of us here, I learn as I go with vehicle repair and it's appreciated. The next run is 52 miles later this week. It may not happen then, but at least I'm armed with the info to attack it when it does.
Take it Easy...
-RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
