honda pump was accessed from the trunk just behind the seat back not in or under the passenger seat , pull carpet back and look for dimples in the metal on the lt side drill one out and see if its the one over the sending unit , then use tin snips and cut a circle out big enough to remove the sending unit and pump.(no sparks/ no power tools)
