Old 09-17-2012, 09:15 AM   #5844 (permalink)
adamj12b
EVVette - '71 Chevy Corvette Coupe
Originally Posted by timmytool View Post
hi
just a question of "potential" if the controller (dc500/1000amp) was driving a
WarP11HV (inter-poled neutral timing dc motor) with a
controller controlled reverse contacter and some
software tweeking
could this setup do regenerative breaking (more for the breaking with no mechanical wearing parts then for power).
My thought with very limited knowledge thinks the inter-poles will allow the motor to do reverse with no commutator sparks etc, if its controller controlled it can be done right (kill power, energies reverse contactor apply desired power level to get regen/breaking).
Setting up the logistics of getting the hardware controls (break pedel/controller/break master cylinder/reverse contactor) might require another control board if the controller cant handle it natively.
This could possibly work, but would actually cause you to use power from your batteries to stop your vehicle.
Would you still have mechanical brakes as a backup?
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
