Originally Posted by seifrob
this would only be possible if i were adding something past the boot lid, Anything strap and or metal hook wise would not work as there are no anchor points around the rear window.
I measured, cut and torch-bent my Polycarbonate sheets, but wound up going a little overboard with my angles... This stuff is just a bit too stiff to work with unless this was heat molded or something(which i did debate to taking to a shop to have done) but im cheap... maybe i'll try again somewhere down the road and have it molded. Even then, Fibreglass is way easier for me. Just not much time for mockup. Lay-up is the easy part, when i do this i want to be able to get it done in a day
