I checked speed vs rpm's in my HX this morning. Before using Marvel Mystery Oil in my fuel, it needed approx 2500 rpm or better to get lean burn. Nowadays I can run lean well below 2000. So try for LB above 2500 to test.
Today I noted:
ScanGauge "LOD" below 60 to go into LB.
Once in LB, LOD over 90-91 will put it out of LB.
Up till today I was using the TPS for same purpose,limits were 19 max to get LB and over 32 would end it. But the TPS limits actually vary with your rpm's, I think LOD numbers are a more consistent guide.
Coast long and prosper.
