Originally Posted by brucepick
I checked speed vs rpm's in my HX this morning. Before using Marvel Mystery Oil in my fuel, it needed approx 2500 rpm or better to get lean burn. Nowadays I can run lean well below 2000. So try for LB above 2500 to test.
Today I noted:
ScanGauge "LOD" below 60 to go into LB.
Once in LB, LOD over 90-91 will put it out of LB.
Up till today I was using the TPS for same purpose,limits were 19 max to get LB and over 32 would end it. But the TPS limits actually vary with your rpm's, I think LOD numbers are a more consistent guide.
Awesome testing Bruce. I have been getting a check engine light for P1164 lately (main 5 wire O2 not reading properly.) Once I upped my RPM's and was going 70-75, I seem to get into lean burn just fine. Once in I can then lower my speed back down to 65 mph. I have a new O2 on order so know if it is the O2 limiting me, or the tall gears / low RPM's of the transmission.
Originally Posted by Jakins
Is LOD scan gauge talk for something?
LOD is a scan gauge abbreviation for engine load. It is a percentage of the maximum power available that is currently being generated to what is being used.
And is there any write ups on what to wire an led or gauge up to see when you are in lean burn?
Yes, I will post some links later today unless someone else beats me to it. As Bruce said, it is for a VX, but they use the same O2 sensor and technology.
I really hate to thread jack, I'm sorry haha. I'm just a really curious person. The car looks great with the HX wheels by the way. I'm surprised you opted to keep the a/c
Thanks. I want really high MPG, but don't want to give up AC. I also want to swap over the power windows and locks to have a few more "luxuries." Once that is complete I will probably put on a car alarm with keyless entry and a truck/hatch release. No remote start though… lol wasting fuel to get the car warmed up? NEVER!
