When I was contemplating a 2F1R reverse trike build, I had planned a simple tube frame with foam between the pipes, then thin foam over the actual pipe to smooth it all out. I would think some sort of solid structure would be of benefit, even with the weight gain it would add.
But, since you have most of a car already foamed up, you obviously know much more than I do on the subject
