Old 09-18-2012, 03:32 PM   #17 (permalink)
myrefugeisintheLord
Learning Aeromodding
myrefugeisintheLord's Avatar
Metro - '93 Geo Metro 4 door hatchback
90 day: 35.26 mpg (US)
Another update.
The drooping corner will be brought up with the last piece added. But I need to address the whole right side before I can finish.
Looking backwards, I cut out the jack point. Leaving the coro there and trying to jack up the back end would result in serious problems! I did cut too much off the piece in front of this one however, so the whole gap is way bigger then I wanted. Hopefully the other side will turn out better!
Also, I'm hoping the coro will be able to move as needed. I only tucked the front part in, about 2" worth. I'm hoping the movement will be taken from that point. I will test it a bit later with the use of jack stands and a jack.
Tomorrow I will be cleaning a house near our house on the mountain. Which we are selling. (Anybody looking for a scenic, mountain retreat in the inland NW? Our home for sale)
I'm hoping there is a window screen somewhere in the building stuff that's still there. Plus I'll be able to pick up some other things I will need to get this finished, brackets, etc. Either way, I'm getting a wire mesh tomorrow for near the tail pipe.
Last edited by myrefugeisintheLord; 12-17-2012 at 12:09 AM.. Reason: reloaded pictures
