Old 09-19-2012, 12:58 AM   #60 (permalink)
freebeard
I should wander into the DIY forum more often...
...likely the front can be from a typical front wheel drive car.
What do you expect for all-up weight? 'Typical' would be somewhere between a Honda 600 and an Olds Toronado. Are you planning on the batteries bringing the weight up to spec?
I like the way you are sculpting the body without a clear idea where the suspension attachment points are. They build skyscrapers that way, start the foundation and design the top floors later. I think it's called fast-track design.
How much do you think electric drive-train design will advance before you are ready for one? You'll probably have the body fiberglassed by the time this stuff is available, but oh man! Cellulose Nanocrystals
Eventually you will need paint. You could finish of with a coat of Nanoclear. Keep it nice for the 'show and tell's.
