Old 09-20-2012, 01:52 AM   #24 (permalink)
Otto
You done good.
Is the coro attached to the control arm, such that it flexes up an down with control arm travel? I've been wanting to try that myself, so am curious.
Also, out of curiosity I'd like to just put the coro on, see what happens with the heat from the exhaust pipe--how much it melts or distorts--then just trim that part out and maybe cover the hole with aluminum window screen. Think that'd work?
And, if you need to reinforce/stiffen a spot for the zipties to go, just insert a short length of appropriately thin wood dowel rod into the flutes.
