Originally Posted by Weather Spotter
Any way to show me the route the belt takes and get me the length code?
Around the alternator, backward against the water pump, around the crankshaft, over the tensioner, back to the alternator:
The tensioner doesn't move in the right direction to actually provide tension, so its basically just there as an idler to keep the belt from rubbing on itself. This makes the belt kind of hard to get on. Kind of really hard.
The belt (dayco) # is 5060380,
(I don't remember the size, but I know it is coded into that number somehow)
