Old 09-20-2012, 01:42 PM   #11 (permalink)
pete c
Originally Posted by moorecomp View Post
Unfortunately, the injectors have 12v coming to them on red wires, and the wires going to the ECU are each different colors for each injector. The ECU grounds the circuit to fire the injector, so interrupting by grounding the signal will open the injector, not kill it. You need to interrupt the 12v coming in on the red wires. Go here and login with the username and password of tech/tech. Go to the bottom, "Auto Repair Reference Center Beta" and find vehicle and your wiring diagrams.
EBSCO Publishing Service Selection Page
So, you are saying that the way to kill the injectors is to open the actual current path of the injector and that the easiest way to do it is to open the 12V side? My cigarette lighter idea would fly in that case.
Does anyone know if there is a way to shut off the injection signal so that the ECU never tries to fire them? Does the ECU fire them directly? I would expect that it did not. I would think that it would have a very low current signal that told something else to actually fire them.
