Old 09-20-2012, 06:17 PM   #45 (permalink)
bondo
bondo's Avatar
Originally Posted by ChazInMT View Post
Would the adhesive back aluminum foil tape used in HVAC work as well on the seams? I'd think it would give you a more uniform surface.
It would work but it would take a lot of rolls to cover that many square feet. Also the aluminum foil tape is pricey per roll. The aluminum foil tape would work good on the edges. You can cover alot more real estate with a big piece of aluminum foil both faster and a lot cheaper.
Bondo
