09-20-2012, 03:30 PM
#41 (permalink)
B.O. Zen
Pickup - '99 Toyota Tacoma 2wd, Regular Cab, Short Bed 90 day: 34.62 mpg (US)
Reading Bobo's thread, and just hanging around here again, is getting me back into thinking about the challenge of MPG....
Need to get rid of my mechanical rad fan, install an engine cut-off switch, shave the mirrors, build an air dam, etc... and leave work early enough on Fridays that I don't feel like I need to hurry, driving up the freeway, to go wherever for the weekend. :P
09-20-2012, 04:59 PM
#42 (permalink)
Nice work a8ksh4! Also a Warning!
I want to warn you, if you are not already aware of this fact, you cannot, I repeat cannot, fiberglass over the type of foam you are using. The styrenes in the resin will attack the foam and basically melt all your hard work into a sticky mess.
You need to put a barrier between the foam and the fiberglass resin before you laminate. Industrial strenght aluminum foil, available at any restaurant supply company, works great. It can be spray glued to the foam. 3M spray adhesive works best.
Carefully cover all the foam with the aluminum foil and tape the intersecting edges with 3M blue painters masking tape. ( I am not a sales rep for 3M, their products just seem to work best, from experience.) Then you can safely fiberglass over the foam.
Best of luck on your project,
Bondo
The Following 7 Users Say Thank You to bondo For This Useful Post:
09-20-2012, 05:06 PM
#43 (permalink)
Aero Deshi
Would the adhesive back aluminum foil tape used in HVAC work as well on the seams? I'd think it would give you a more uniform surface.
09-20-2012, 05:12 PM
#44 (permalink)
B.O. Zen
Oh, I had though that it was okay to lay the glass directly over the foam so long as I used an epoxy resin, rather than a polyester resin. Is that not true?
The Following User Says Thank You to a8ksh4 For This Useful Post:
09-20-2012, 05:17 PM
#45 (permalink)
It would work but it would take a lot of rolls to cover that many square feet. Also the aluminum foil tape is pricey per roll. The aluminum foil tape would work good on the edges. You can cover alot more real estate with a big piece of aluminum foil both faster and a lot cheaper.
Bondo
09-20-2012, 05:19 PM
#46 (permalink)
You are safe with epoxy.
Glad to hear you are using epoxy resin. It is the best by far. I just wanted to warn you what the polyester resin would do.
Carry on,
Bondo
The Following 2 Users Say Thank You to bondo For This Useful Post:
09-20-2012, 05:21 PM
#47 (permalink)
B.O. Zen
Ok, cool! Thanks for the heads up, Bondo.
09-20-2012, 07:17 PM
#48 (permalink)
Wiki Mod
I used (Dow brand) blue foam and polyester resin and it only melted in about 1/8". i found that if I made the foam the size I wanted the final shape to be the fiberglass would melt in and (stick hard) as well as end up the same size as the foam had been.
It might not be the same for you but thats what worked on my tail.
09-20-2012, 08:02 PM
#49 (permalink)
This is a really cool project you've got going on. Can't wait to see the finished product.
Aerospace Controls Engineer.
Currently driving a mostly stock 2014 Mitsubishi Mirage DE hatchback.
09-20-2012, 09:41 PM
#50 (permalink)
I watched a series of 6 segments using pink polyester foam and poly resin and they had no reaction between it, they were making a t-bucket. I think the 3in radious solution you came up with was a good one adds strength , and you beat me to the foam seal between the cab and cover . I dont use my campershell on my 2003 techoma it works my mpg by 4-5mpg . I need a cover and if what you are making works ABA I will copy it if you dont mind.
