Old 09-20-2012, 06:19 PM   #46 (permalink)
bondo
bondo's Avatar
You are safe with epoxy.
Originally Posted by a8ksh4 View Post
Oh, I had though that it was okay to lay the glass directly over the foam so long as I used an epoxy resin, rather than a polyester resin. Is that not true?
Glad to hear you are using epoxy resin. It is the best by far. I just wanted to warn you what the polyester resin would do.
Carry on,
Bondo
The Following 2 Users Say Thank You to bondo For This Useful Post:
BamZipPow (09-02-2013), HHOTDI (12-14-2012)
