Old 09-20-2012, 06:16 PM   #8 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Originally Posted by Beau View Post
Some also attest to adding one ounce of TC-W3 per five gallons of gasoline (a ratio of 1 to 640). There are many reasons why this is recommended and many of the potential concerns (plugged cats, etc.) do not appear to apply. I have tried it (A-B-A-B) and have my own results; however, I don't want to be bashed or have my testing practices questioned -- since that normally results (on various websites) whenever these types of fuel additives are discussed.
Not any different than a little MO once and a while, beyond the potential small pollution implication I don't really understand the bias against top end lube.
Its not like its new or doesn't work, certainly not a unicorn but it also doesn't always increase fe depending on your motor and its design. It generally reduces wear if used at the proper concentration.
It also can allow a motor that is not functioning correctly to run better (as I can attest to) right or wrong its a lot easier than doing the right thing and rebuilding.
