Old 09-20-2012, 08:09 PM   #30 (permalink)
brucepick
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Originally Posted by Jakins View Post
So if you stay below 20tps and above 2400 rpm on the freeway for 2 miles it will turn on by itself?...
Good that you asked:
You only need TPS 19 or lower when you actually want it to go into LB. Before that over the two miles, just don't stomp on it. And once you get it into LB you use the second set of rules (shorter set) to keep it in LB.
Also - and I left this out before - coasting in gear with foot off the accelerator seems to disable lean burn even if you already had it. Coasting in neural is OK, you will be able to get LB back after maybe 5-30 seconds of following the other guidelines.
Coast long and prosper.
The Following User Says Thank You to brucepick For This Useful Post:
Jakins (09-20-2012)
