Old 09-21-2012, 02:37 AM   #16 (permalink)
AndrzejM
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
Originally Posted by JacobAziza View Post
When we removed PS from her matrix, I just bought a shorter serpentine belt, and rerouted it to skip the PS (and AC).
I drew out the belt diagram you posted above, and figured out a path that would turn everything the correct way while skipping the unnecessary stuff, then measured it with a piece of string and told the parts store the length of the belt I wanted in mm.
It took 3 trys to get the right length, and getting the belt on was a little bit challenging, but it gone on just fine in the end.
I've went the same way with Berta. When I've removed AC (it was driven by additional belt), and PC pump (to save weight) I just took the measurement of the serpentine belt I would need to drive the rest of the pulleys and bought one with the correct lenght.
3 - PS pump - removed
green line - new serpentine belt route
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
