Old 09-21-2012, 10:37 AM   #5846 (permalink)
blacksun1989
Problem with my Open Revolt Controller
Hi im new here and i dont know if im right here or not.
But i have issues with my OpenRevolt Controller. so i build the 2c version with a already programmed controller from Paul and sabrinas website. Now when i turn it on the green Led turns on and after a second the yellow led starts blinking. And thats all. I use a small lifepo4 battery to power the unit and i added a small poti from 0-5k ohm. Not a real gas pedal just a normal poti like you get a mouser or digikey. But i guess that should not be the problem.
What can i do? What does the yellow flashing mean?
thanks from germany
Johannes
