Originally Posted by DoctorM
So much emotional baggage here.
I just mentioned what I read -- to see if anyone here had tried it. I don't have an emotional stake in it as some of you apparently do.
As has already been pointed out, putting it in a vehicle subjects the result to tester bias - pro or con. Until its tested in an engine on a dynamameter, it remains a candidate for further consideration.
Try not to get so emotional about it - it calls into question your impartiality.
Emotion? Care to point it out?
So you're going to pull your engine, put it on a dyno and test this. Great! Let us know what you find out. Btw, I never said it wouldn't work.
Just out of curiosity, how much does acetone cost per gallon?
