Originally Posted by Daox
Very nice Dave! I take it the noise we hear is the fan on the motor? Or, is it more from the transmission gears?
It's both, but mainly the transmission gears. Everything seems balanced, just a noisy transmission. I've had them up to 3800 RPM without any problem, and my Zilla is limiting my motor to 4800 RPMs for safety.
I need a problem KWh meter, but my guess on yesterdays abusive drives was 305 wh/mi from the wall. It was about 2.5 hours on 220v 2.2KW Elcon, so I am just guessing. That was 18 miles of the worst hills I could find, punching it on every acceleration, and basically doing every non-eco friendly driving thing I could think of, with 2 passengers. Most of the drive was 35-45 MPH showing off what the car can do.
Now I am getting the heater to function, I just found out which connector from the Honda Heater Control Unit I am going to use and now I'm working on a simple comparator circuit to turn the heater + pump on when the Temp Control is set to Full Heat.
