I went a total of 18 miles on the first full charge and was extremely impressed. I can zip up and down the nastiest hills in the area, I can hit all the speeds I need, and at some point it will get some highway testing. Next I am going to hookup the tach, get the heater working, wiring in the charging socket and then I can start commuting full time! I am also going to start logging most of the trip to collect data, but the AH counter on the ZillaConfig software isn't correct, it seems to be double what is should be, so I am looking into that.
Civic EV http://2001-civic-ev.blogspot.com/ Solectria Force http://solectriaforce.blogspot.com/ |
The Following 6 Users Say Thank You to TheSGC For This Useful Post: | 2000neon (09-23-2012), Cd (09-23-2012), Cobb (09-22-2012), eco_generator (03-01-2014), samwichse (02-15-2013), thingstodo (09-23-2012) |
09-23-2012, 09:13 AM | #86 (permalink) |
CM400E - '81 Honda CM400E 90 day: 51.49 mpg (US) Daox's Grey Prius - '04 Toyota Prius Team Toyota 90 day: 49.53 mpg (US) Daox's Insight - '00 Honda Insight 90 day: 64.33 mpg (US) Swarthy - '14 Mitsubishi Mirage DE Mitsubishi 90 day: 56.69 mpg (US) Daox's Volt - '13 Chevrolet Volt Thanks: 2,501
Very nice Dave! I take it the noise we hear is the fan on the motor? Or, is it more from the transmission gears?
09-23-2012, 10:11 AM | #87 (permalink) | |
I need a problem KWh meter, but my guess on yesterdays abusive drives was 305 wh/mi from the wall. It was about 2.5 hours on 220v 2.2KW Elcon, so I am just guessing. That was 18 miles of the worst hills I could find, punching it on every acceleration, and basically doing every non-eco friendly driving thing I could think of, with 2 passengers. Most of the drive was 35-45 MPH showing off what the car can do. Now I am getting the heater to function, I just found out which connector from the Honda Heater Control Unit I am going to use and now I'm working on a simple comparator circuit to turn the heater + pump on when the Temp Control is set to Full Heat.
09-23-2012, 01:33 PM | #89 (permalink) |
Hyper-miling an EV is quite different, Pulse and Glide doesn't work, you want constant current draw and just glide whenever possible. Accelerating is where you loose your efficiency the most. You also want high RPMs, 3500-4500 RPMs if possible because this is where the motor is most efficient with the least current draw and the internal fan running the best.
09-23-2012, 09:20 PM | #90 (permalink) |
I installed my charging socket on the EV today and I figured out how to wire up the heater controls to the existing Honda heater control panel.
I am hoping to get my new EV plates tomorrow and try to get commuting next week. I want the heat running before I start commuting because the weather is getting much colder now and I don't like fogged windows.
