Well I took mine to the battery place last week and they pulled all the batteries and discharged and recharged them. The guy there said the front 2 discharged too quickly with his 75 amp discharger, even though when I checked them with my VOM the numbers were all around the same. It's much better and I'm not experiencing the overheating problem or limiting that was going on before so maybe it was low voltage and not the controller. His concern was that my onboard charger wasn't charging them up enough. He's checking to see if he has access to one that will work with the Miles, and I'm searching as well. I noticed the new models come with a Delta Q, but I have no idea which model. Any suggestions are appreciated
Thanks
