Old 06-09-2008, 01:31 PM   #153 (permalink)
ebacherville
Veggiedynamics
Volt12 - '12 Chevy Volt base
Originally Posted by Tango Charlie View Post
You must be using polyester resin. To 'glass over foam, use epoxy resin. But it's more $$$ and touchier with the catalyst ratio. i.e., You can't speed it up with more catalyst. To obtain full strength it must be mixed to its specified (on the label) ratio. If more catalyst is added, it may not even cure completely. But anyway... It sounds like you found a way to work around it.
YEah im just using what i can get easily .. bondo brand fiberglass resin.. works well if using compatible materials.. .. and i assumes thats what people are looking for readily available materials they can pick up anywhere..
