Old 06-09-2008, 09:35 AM   #151 (permalink)
Veggiedynamics
Volt12 - '12 Chevy Volt base
last night i pulled out my forms and drew my profile on the inside walls ready to be cut down.. got the hatch opened up again.. the struts still hold it up even before trimming
Waiting for the foam to cure up still.. rushing this process could mean drastic problems.. but yet until I get the hatch part done i cant do the rest of the tail... oh the drama
Old 06-09-2008, 12:56 PM   #152 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Pontiac Vibe base
90 day: 36.01 mpg (US)
R2-D2 - '00 Honda Insight
90 day: 58.81 mpg (US)
Thumbs up
Originally Posted by ebacherville View Post
Progress:
heres is a warning PINK FOAM INSULATION melts with fiberglass.. use the foil backed yellow foam insulation .. found out the pink foam isn't the stuff to use..
You must be using polyester resin. To 'glass over foam, use epoxy resin. But it's more $$$ and touchier with the catalyst ratio. i.e., You can't speed it up with more catalyst. To obtain full strength it must be mixed to its specified (on the label) ratio. If more catalyst is added, it may not even cure completely. But anyway... It sounds like you found a way to work around it.
-Terry
Old 06-09-2008, 01:31 PM   #153 (permalink)
Veggiedynamics
YEah im just using what i can get easily .. bondo brand fiberglass resin.. works well if using compatible materials.. .. and i assumes thats what people are looking for readily available materials they can pick up anywhere..
Old 06-09-2008, 10:04 PM   #154 (permalink)
Veggiedynamics
well checked on the foam today and its still curing still a few soft spots.. hopefully tomorrow it will be good to go..
Old 06-09-2008, 11:23 PM   #155 (permalink)
Blue - '77 Chevy P/U
what about a primer-sealer then the resin ???
Old 06-09-2008, 11:34 PM   #156 (permalink)
Veggiedynamics
well i went out and started shaping one side.. its looking good but ran out of light.. tomorrow ill finalize the shape then try to match the other side..
Old 06-09-2008, 11:35 PM   #157 (permalink)
Veggiedynamics
primer melts the pink foam also , the white/yellow foam it doesn't..
Old 06-09-2008, 11:53 PM   #158 (permalink)
OK
Old 06-10-2008, 11:56 AM   #159 (permalink)
2 part foam
This 2 part foam is one solution to your curing problems.
HTML Code:
http://www.pegasusautoracing.com/productdetails.asp?RecId=103
8
"This polyurethane foam kit produces a rigid foam with a density of about two pounds per cubic foot. It is ideal for making custom fitted seats or for strengthening composite body parts. When the two parts are mixed, they begin to react within about one minute. Most of the foaming occurs within the next several minutes. About 15 minutes is required for the foam to set. Allow several hours before any secondary operations are attempted such as sanding or carving (if required). The resulting foam will not absorb water and is not affected by polyester resin, epoxy resin, gasoline or oil. The compressive strength of the foam is 36 psi. It can withstand operating temperatures of up to 200°F. One kit is enough for about 3 typical formula car seat inserts."
I would have been inclined to use ridged foam block, carve the shape and glass over it.
Old 06-10-2008, 12:11 PM   #160 (permalink)
Veggiedynamics
the foam isn't really a problem just takes extra time.. however a few hours would save some time.. but that OK things are moving along fine.
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1056 12-14-2024 12:21 AM
crx hf help need more info, rear wheel skirts RP-CLMBR Aerodynamics 2 07-16-2008 09:24 PM
Repping the old school Hondas - 85 CRX HF 1GCRXHF Introductions 4 06-16-2008 01:14 PM
New to the forum, with my RX-7 EV Project... BigMouse Fossil Fuel Free 14 02-28-2008 04:14 PM
AFS Trinity EXTREME Hybrids!!! cfg83 General Efficiency Discussion 10 01-18-2008 07:15 PM
