Old 09-25-2012, 12:48 AM   #2 (permalink)
2000neon
2000neon's Avatar
VX - '94 Honda Civic VX
90 day: 47.95 mpg (US)
Do you know the code is that is causing the check engine light? If you don't have a code reader there is probably some "key dance" to tell you, For example with my Neon, with the car off I cycle the key to "on" without starting the car, and back to off three times, then on the last time the digital odometer will read out the codes. Your Honda is probably a different set of steps, but likely still a way to do it.
