Old 06-09-2008, 05:20 PM   #158 (permalink)
Coyote X
nut
Coyote X's Avatar
Metro XFi - '93 Geo Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 Suzuki DR650SE
90 day: 55.26 mpg (US)
Send a message via MSN to Coyote X
I got some painting done but it is all still white paint so not much to show in pictures. The white makes any places show up well so I have been filling and smoothing any bad places in the body and painting it back white. I have everything looking real good now and the body is as level and flat as I am going to get it.
I hauled it in today and had a windshield installed and tomorrow the tires should be in so it will be able to drive on 4 tires that match. I was planning on prepping it with 180 wet sanding tues and painting it wed but it looks like I have to put it off a day so I can do some other work wed. So probably Thursday I will have a blue car.
Then it is just a matter of some minor details and prob hit the road with it this weekend if everything seems ok. One of the calipers I used is sticking real bad and the vacuum booster doesn't seem to work well so I know there are a few things I need to swap out but nothing real major at least. I also forgot to put the keeper pins in the ignition switch so it falls out of the hole
There are always little annoying things to fix when rebuilding a car......
