Old 06-02-2008, 11:52 PM   #151 (permalink)
90 day: 51.82 mpg (US)
Excited about the new paint. Going blue, like inside?
Old 06-03-2008, 12:52 AM   #152 (permalink)
nut
Coyote X's Avatar
Metro XFi - '93 Geo Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 Suzuki DR650SE
90 day: 55.26 mpg (US)
Send a message via MSN to Coyote X
yep but first it is getting painted white so i can find the last few bad spots and scratches in the finish then it is getting painted blue. The white base coat gives the blue a nice bright finish
Old 06-03-2008, 07:34 PM   #153 (permalink)
nut
Coyote X's Avatar
Old 06-04-2008, 07:44 AM   #154 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
I say leave it white. White hides all imperfections and is cooler in the hot sun.
GeoMetroforum.com - got mpg?
Old 06-04-2008, 11:26 AM   #155 (permalink)
Yaris Cruiser
but it doesn't look as cool : in white as it will in blue
Old 06-04-2008, 01:16 PM   #156 (permalink)
I assume you're not going to be using those tires.
Oh, the peanut gallery is out in full force today...
Old 06-09-2008, 11:54 AM   #157 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Pontiac Vibe base
90 day: 36.01 mpg (US)
R2-D2 - '00 Honda Insight
90 day: 58.81 mpg (US)
This thread makes me want to go right out and buy a mig welder! Amazing project! Did you get any painting done over the weekend, Coyote X?
-Terry
Old 06-09-2008, 05:20 PM   #158 (permalink)
nut
Coyote X's Avatar
I got some painting done but it is all still white paint so not much to show in pictures. The white makes any places show up well so I have been filling and smoothing any bad places in the body and painting it back white. I have everything looking real good now and the body is as level and flat as I am going to get it.
I hauled it in today and had a windshield installed and tomorrow the tires should be in so it will be able to drive on 4 tires that match. I was planning on prepping it with 180 wet sanding tues and painting it wed but it looks like I have to put it off a day so I can do some other work wed. So probably Thursday I will have a blue car.
Then it is just a matter of some minor details and prob hit the road with it this weekend if everything seems ok. One of the calipers I used is sticking real bad and the vacuum booster doesn't seem to work well so I know there are a few things I need to swap out but nothing real major at least. I also forgot to put the keeper pins in the ignition switch so it falls out of the hole
There are always little annoying things to fix when rebuilding a car......
Old 06-10-2008, 09:12 PM   #159 (permalink)
nut
Coyote X's Avatar
Yes I actually got enough lug nuts finally and all the wheels are properly bolted on
I like those tires they are Sumitomo HTR 200 175/70R14 LRR tires. They fit the fenders perfectly The might rub a bit but that is what a sledge hammer is for. If it rubs the fender lip I will just chop it off probably. The car is now like 10 inches off the ground and I could climb under it easily without jacking it up so I am going to have to cut the springs way down. Probably 2 coils to get it back to normal. I have to find a 16 tooth speedometer gear to get it accurate but I can pick that up from a suzuki dealership sometime since they probably aren't easy to find in junkyards.
Old 06-10-2008, 09:22 PM   #160 (permalink)
That ground clearance is insane. I can't wait to find out how much weight you chopped out. And... new convertible top?
MPG Gauge for the Geo Metro XFi Wayneburg General Efficiency Discussion 2 03-10-2011 07:48 PM
Geo Metro Conversion - Standard to XFI SirKeats EcoModding Central 16 10-22-2010 02:44 PM
1995 Geo Metro DRL disengage tip akcapeco EcoModding Central 1 06-10-2008 11:07 PM
CL: Mechanics Special 94 Geo Metro Red For Sale 4 04-09-2008 02:48 PM
Video: Geo Metro Commercial! Peakster General Efficiency Discussion 5 12-13-2007 10:54 PM
