Originally Posted by dremd
this may resolve itself when I switch from motor oil to pump oil (soon).
Use gear oil.
MAYBE a spot free style reverse osmosis filter to avoid drying.
Sounds pricey. I have been using a $17 charcoal filter for an RV and a $9 calcium neutralizer for water mist systems on my pressure washer and it has cut down the spots quite a bit.
Both filters have garden hose connectors.
My pressure gauge should arrive soon, I'll report back after I've tried it.
I hope you got a liquid filled gauge or at least use a pressure pulse dampener.
Because the needle on a regular dry gauge will bounce all over the place.
