Old 09-26-2012, 06:41 PM   #5858 (permalink)
jedsmd
PLUGnGO
jedsmd's Avatar
Originally Posted by Crossdan View Post
Weird is right. The relay is 5volt rated up to 28v. Works fine when i attach it directly to a 12v battery. When I hook it up the middle and bottom of J1 the voltage drops from 12.8 to 1.5 volt and the relay doesn't latch.
I'm stumped!
Hi CrossDan
Have you fixed it yet?
If not,
Looking at the schematic I think the relay should connect between pins 2 and 3 of J1 (Contactor and ground) rather than middle and bottom as you state above (contactor and throttle pot)?
Jerald
