Originally Posted by Crossdan
I have another question about the pre-charge connection. After the pre-set time I get the 12volts between the +12v and middle terminal of J1. However when I attach a relay it won't pull down. I eliminated all wiring thinking the resistance was too high and jumpered directly to a small pcb mountable relay. Still no luck. Anybody have any ideas?
Thank,
Dan
Crossdan
Shouldn't the 12 volts be measured between the middle terminal and ground?
12v measured between +12 and contactor would indicate that the contactor pin was low and had not turned on.
Jerald
