Old 09-23-2012, 01:55 PM   #5851 (permalink)
I have another question about the pre-charge connection. After the pre-set time I get the 12volts between the +12v and middle terminal of J1. However when I attach a relay it won't pull down. I eliminated all wiring thinking the resistance was too high and jumpered directly to a small pcb mountable relay. Still no luck. Anybody have any ideas?
Thank,
Dan
Old 09-23-2012, 04:25 PM   #5852 (permalink)
PaulH
MPaulHolmes's Avatar
Well that's weird... Was it a 12v relay? I've tested it with an EV200 and a schrack pcb relay. What's the voltage from the middle of J1 to the bottom of J1 when the relay is attached?
kits and boards
Old 09-23-2012, 08:33 PM   #5853 (permalink)
Weird is right. The relay is 5volt rated up to 28v. Works fine when i attach it directly to a 12v battery. When I hook it up the middle and bottom of J1 the voltage drops from 12.8 to 1.5 volt and the relay doesn't latch.
I'm stumped!
Old 09-23-2012, 10:12 PM   #5854 (permalink)
Some more data. I measured the amps the relay draws when connected to the battery. Comes out to 180ma. Did the same thing when connected to the controller. I got a reading of 30 ma. So it seems the controller isn't putting out enough amps to latch a relay. Does anyone know what amperage should be coming out of the controller?
Old 09-24-2012, 12:46 PM   #5855 (permalink)
Somebody, who knows the hex fault bit values could tell me what is 02?
Couldn't find any cross reference, just fault code names and a few binary values, none of them are hex 02...
Cheers
Old 09-24-2012, 08:07 PM   #5856 (permalink)
PaulH
02 is the vref fault. That means that either the current sensor is unplugged, or maybe the wires are soldered in the wrong holes, or it's a bad current sensor, or some weird 4th option I can't think of.
crossdan, are you sure about the orientation of the Q1? Could you take a picture of that part of the board?
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
zsnemeth (09-25-2012)
Old 09-25-2012, 09:11 PM   #5857 (permalink)
Here are the pics of the board.
ID:	11560   Click image for larger version
Old 09-26-2012, 06:41 PM   #5858 (permalink)
PLUGnGO
jedsmd's Avatar
I'm stumped!
Hi CrossDan
Have you fixed it yet?
If not,
Looking at the schematic I think the relay should connect between pins 2 and 3 of J1 (Contactor and ground) rather than middle and bottom as you state above (contactor and throttle pot)?
Jerald
Old 09-26-2012, 08:11 PM   #5859 (permalink)
Hi Jerald,
No, I haven't fixed it yet. Connecting to pins 2 & 3 doesn't give any voltage.
I can think of a few workarounds so I'll mull it over while I install the controller in the car and do some tests.
Dan
Old 09-26-2012, 08:19 PM   #5860 (permalink)
PaulH
It sounds like the P channel mosfet isn't working right, or it's got a really high resistance while on for some reason. I'm going to build the circuit and see what's going on. I'm sorry about this!
kits and boards
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3431 05-04-2022 05:43 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
