Old 09-27-2012, 02:25 PM   #57 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
Originally Posted by a8ksh4 View Post
Once I had the curves cut, I went back with a regular flat sanding block and 80 grit and used it to smooth out and blend the corner into the side.
This is turning out really nicely.
The shell is a hare larger than the cab in some places. I'm wondering if I should sand it down all the way around the leading edge so that it is 1/4" inside the cab profile. Any ideas?
That's the ticket - put a radius on it.
ABA testing will defiantly come next week! What would be the best testing to do? We have good hills around here for coast down testing in neutral or I could record fuel used along a few miles of freeway where it's flatter.
I'd say either is fine, provided you try to control as many variables as possible and warm up the engine/drivetrain/tires before you try running the tests. (Though of course people prefer to see MPG numbers rather than seconds of coast-down time.)
Do you have cruise control? Taking your foot out of the equation would be preferable if you're going to do MPG testing.
You've probably seen this already: http://ecomodder.com/forum/showthrea...ery-11445.html
