Bestclimb is spot on. Oh, and 60 miles? That must put you around Big Lake then? I grew up in Wasilla, and my family is still in that area. I hardly recognize it every time I go back.
I would say oil pan heater or synthetic engine oil is needed, both would be nice.
As for the tires, studs are counterintuitive, they are more beneficial in more moderate climates. Most of the time up there, when it's icy, it's cold enough that it's not real slippery. Ice is worst when temps are right about freezing, and those are the conditions where you really want studs. Plus, the roads get cleared regularly and sanded. When it's snowy, studs do almost nothing, it is all about what tire you have. Most people have a set of winter wheels and summer wheels, especially if you run studs. As long as you're not off-roading, 2WD is all you need.
